Adapter Lug Bolts To Studs?
Old Feb 28, 2012 | 05:34 PM
Default Re: Adapter Lug Bolts To Studs?
...Deleted...
Old Feb 28, 2012 | 07:15 PM
maxcichon's Avatar
Duh, I don't know why I said conical, I meant BALL. I got locking lug bolts a time ago and it took the supplier 3 times to get it right. I even told them that they had to be BALL on the first order. I had a brain fhart, I did. Ball lugnuts, thats for sure and I should have said that. Now, I have looked and looked, but for sure the 12mm X 1.50 AND the length has to be right.
Confused no more!
Wheel Stud Screw Type
Old Feb 29, 2012 | 08:21 AM
I believe this is what I want to do. I don't need anything else but to just be able to 'hang' my wheels and mount with lug nuts. Will be looking into these for sure. I believe the part that screws into the hub is 12 x 1.5 so thats where I'll start. Then I will have to make sure the lugnuts are conical, and the bolt part doesn't protrude past where the cap snaps on.
Keep us posted, I think it would be a worthwhile swap, especially with the locktite, I would think with some heat you could go back to OEM without needing new hubs, thoughts?
Old Feb 29, 2012 | 08:36 AM
maxcichon's Avatar
Sure. Cleaning of the threads after removal of the LokTite is no problem. It is, after all, made to be removable. Double nut-it to unscrew and use their solvent to remove.
Old Feb 29, 2012 | 09:33 AM
...Deleted...
Last edited by GraphiteGhost; Oct 6, 2021 at 12:26 AM. Reason: Added questions at the end.
Old Feb 29, 2012 | 10:43 AM
I would not trust $0.89 studs with my life or anyone else's. These are made in China for sure and could be made from recycled rebar from the last new building to fall down or anything else they found laying around.
For ease of putting the wheels on Waldigs post will solve that.
https://www.crossfireforum.org/forum...ud-5-each.html
You can even use a screw driver in the hole.
I line up the wheel slightly under the hub and slanted out and lower the jack until the wheel rolls on, sounds tricky but isn't, but saves your back with no lifting at all. With the wheel on just turn it until a bolt lines up.
Old Feb 29, 2012 | 10:49 AM
MikeR's Avatar
check with Mad_Med.... he has them and they fit under his caps of his aftermarket wheels.... I dont know if he had it done or bought it that way though... I'll text him...
If you use red loctite you can undo the mod later with heat.... just dont use epoxy!
Old Feb 29, 2012 | 11:27 AM
...Deleted...
Old Feb 29, 2012 | 11:43 AM
Has anyone else done this before? What did you get for the length?
Seems simple enough, measure the overall length of your current bolts, compare the new nut length with the head of your bolt. Adjust to suit.
I find lining up with studs harder than what we have and what we have costs nothing, win win in my book. You always want to save a buck and here you are spending what you saved. LOL
Studs saw away on the wheel and scratch the back of the wheel.
Old Feb 29, 2012 | 11:48 AM
...Deleted...
Old Feb 29, 2012 | 01:17 PM
maxcichon's Avatar
Only thoughts I have are the length. They have to be long enough to take the full threads of the lugnut and short enough to fit under the cap. I see 1.5" and 1.75", wonder how many other sizes there are? I see they are shallow where they go into the hub so depth isn't a problem there. Locktite should be a must too. Oh, and one of them HAS to be a security lugnut, one on each EXPENSIVE wheel/tire! I like this idea and will have to scope this out for lugnut (BALL seat) length.
If you keep them the same length as the OEM lug bolts (including the head!), they should do the job.
Old Apr 8, 2012 | 02:52 PM
robertalive's Avatar
H&r sells double ended studs.the nice part is they have an allen key on the part sticking out towards the wheel so you just have to buy 12mm x 1.5 male,put red loctite and a 12mm x 1.5 female on the other end.there 8.50 a piece.dont know bout using spacers with those ,Moroso doesnt recommend using spacers with its stud conversions.i agree with most people in saying that spacers and adapters are just compensations for having the wrong wheels.if all you want is convert,i did also the stocks are a pain to mount,mount and spin,lol.i tapped to 14mm x 1.5 to fix stripped threads from overtightning at tire shops and now am converting the studs and dont want any spacers to be honest.just bought a 18" x 9.5" for the rear with 35 series tires and am working out a 3" drop.want 18" x 8" with a 30 series in front with 3.5" drop.
Old Apr 9, 2012 | 08:44 AM
...Deleted...
pholmes237@yahoo.com
Jun 10, 2018 09:16 AM
gblack32
Sep 30, 2015 01:13 AM
SoftballJunnkie
Mar 10, 2011 08:49 PM
oceans2c
Dec 15, 2008 10:20 AM
bmerfan
Sep 23, 2004 07:57 PM
