Old Feb 29, 2012 | 10:43 AM
onehundred80
Default Re: Adapter Lug Bolts To Studs?
I would not trust $0.89 studs with my life or anyone else's. These are made in China for sure and could be made from recycled rebar from the last new building to fall down or anything else they found laying around.
For ease of putting the wheels on Waldigs post will solve that.
https://www.crossfireforum.org/forum...ud-5-each.html
You can even use a screw driver in the hole.
I line up the wheel slightly under the hub and slanted out and lower the jack until the wheel rolls on, sounds tricky but isn't, but saves your back with no lifting at all. With the wheel on just turn it until a bolt lines up.
