Re: Man down
Good luck. I am battling a somewhat similar issue. After getting the SC bearing fixed the car drove fine. Next morning the car would barely run and you could smell unburnt fuel. Disconnect the battery and the car runs fine all day. Let it sit overnight and it does idles like *** again. Getting a P0105 on OBDII reader but I believe the SDS is showing something an undetermined fault.
Still waiting to see if a map sensor has really gone bad or if it is something else.
