Originally Posted by hcarter
Saga continues , finally the rear springs have settled in and i'm too low even with dot4 pads tires have a rubbing issue when at wot or a tight rt, hand curve ,so I ordered a set Of Eibach from Rob (of course) to get the rear springs ,the front of the car is tight and perfect no issues there , hopefully after the spring swap I'll be finished with the suspention and can actually go enjoy the car.
I feel you, Howard. I REALLY like the look and feel of the upgraded/lowered suspension, but the amount of time and money on parts it takes to make it all work the way it should it really adding up. Now Mike has made the adjustable links for the rear sway bar and I need to do those too
