Re: offset wheels?
Thanks for all the examples, this is starting to make more sense.
10” wide wheel +20mm offset with 285’s= 17mm out more and 12.5mm in more than a stock wheel.
10” wide wheel +25mm offset with 285’s =12mm out more and 18mm in more than a stock wheel.
So the TSW Max
10” wide wheel +40mm offset with a 20mm spacer= 17mm out more and 12.5mm in more.
If a 20mm spacer is used then it should be equivalent to the +20mm offset right? BUT, is there such a thing as a 20mm spacer and would there be any safety issues?
