offset wheels?
Originally Posted by srt666
A 20mm rim with a 20mm spacer?
From what I have read and understand above, the +20mm offset on a 9.5" wide rim will work without spacers and will give you 7mm outside and 3mm inside wider than stock (if using a 265 tire).
So I can get an 8 in rim with a 32mm offset. How big of a lip would I end up with
It says it right there on the webpage... LMAO
TSW Alloy Wheels | The Snetterton in Hyper Silver and Chrome| www.TSW.com
1" is your answer
Back you will want a spacer.
I don't think a 9.5 -40 will work to well on front.
What size of tire are you thinking of?
I run a 235/275
I run a 235/275
Are you sure that you want to upset the balance running 19's up front? I think you might run into some clearance issues.
Nope I have 19x8.5 up front and 20x10 in the rear. Rides better now than it did with the stocks....nice and smooth even on rough roads.
Mackel
Sep 29, 2015 02:41 PM
ritous1
Sep 26, 2015 01:27 PM
