I was an MECP certified individual and installed (professionally) stereos for several years, you will excuse me if your experience or knowledge trumps mine.
All I am trying to do is warn a member that he is going to want to avoid that area for an amp nearly 5x the power, unless he adequately tests the temperature while running in this space. When I did my multip amp system in the XF, I dit not consider this area because of these concerns.
To tell someone, 'well the engineer made it work for 200W (and it still doesn't stay very cool) but I am sure 900W will be fine' is irresponsible IMHO
Done trying to help.
I guess it must in some areas.. I KNEW THERE WAS A COOLING HOSE..
Now carry on with how wonderful your knowledge base is.. by all means.
