Originally Posted by jabk
I was going to go test it out with a new battery today, and if that doesn't work, i was going to check the cables from the battery to the starter. perhaps they came undone.
or i could check with a multimeter and see if any voltage is even getting carried to the starter.
i just dont think it could be the fuel pump because then the engine would at least TRY to crank. and i don't believe it's the ignition.
I would seriously think you are only looking at a battery, connection, or a relay issue. Fuel pump? When you turn the key to the first postion you should hear it "spooling up" so to say. Have you taken a look at the contacts on the relays on the RCM? Just a thought..
