Originally Posted by Livinloud
Well I ran into a problem. I putting my amp in the back with the sub. But I have no clue where to run the power wire through? I found the main harness and it's blocked by heat shields and I don't want to mess with it. Where did you all run your power through?
One the other hand I got my headunit in and looks pretty good being all black and shiny.
"Guessing" you are wanting a direct to battery hookup, If you pull the battery and tray you will find a rubber grommet with several openings in it to feed the power wire. Comes out down by the OEM amp, pull the door sills and run under the carpet and feed into the rear fender well area. There is already and array of wires there and mine just kinda snaked in with the rest.
https://www.crossfireforum.org/forum...s-05-base.html
Video here should help a lot..
