Thread: Starting Issue
Old Mar 11, 2012 | 10:23 PM
Mrmiata's Avatar
Mrmiata
Default Re: Starting Issue
Originally Posted by poolboy
Thank you for your reply.
I did clean the terminal clamps, and ground screw from the battery to the body. no luck, any idea why it would start when hooked to a charger/starter unit? but not by the new battery alone?
I have not been able to get under the car to check the hot line/starter connection from the battery.
Solenoid engaging but starter not turning kind of "won't turn over"..nothing at the key when turned to start? If the first I'd have to wonder if starter isn't going and needs the extra boost?
