Old Mar 14, 2012 | 01:17 AM
aupaul's Avatar
aupaul
Default P2098 K299 No hair left
Ok guys I do not have an SRT6. I have a limited Roadster. But you folks are more into code scanning and logging. I have been fighting two problems. P2098 check engin light. And heat on all the time. Today my research of the p2098 shows a cause could be (k299) 02 1/2 Heater control circuit. WOW could this all be the same one problem?? As for the heat on all the time I can add ground to the lead on the heater control valve and heat goes away. Indicates heater control module.
P2098 I have changed all 4, 02 sensors. cleaned MAF and throttle body. Swapped fuel injectors from one bank to the other. and replaced crankshaft sensor. ANY IDEAS??? Help please......And THANKS
