Thread: Fuses
Old Mar 14, 2012 | 02:46 PM
Mr Kilmouski's Avatar
Mr Kilmouski
Default Re: Fuses
Originally Posted by Robskytoon
Thanks for the info - found it and naturally its the opposite to the handbook with fuse 1 at top right not top left. Fuse 10 checked and OK but noticed some corrosion on blade so used multiple insertions (!) to clean up and lo we have light
Tony
Glad you sorted the problem. I would check other fuses to see if any more corrosion is present. you may have a leak on the seals around the windows. I use something called "Gummifledge" which the SLK guys use which for want of a better phrase re-hydrates the seal and prevents leaks.
Very happy that you are finding the forum so useful. Next you'll be starting the mods, but beware it can become an obsession. I have done a few and only had the car since beginning of december 2011. Had the SLK320 before that and pulled loads of parts before I px'd it. Parts are just so interchangeable.
Whereabouts are you in the UK, your profile gives no clues, maybe someone more knowledgeable than me is close to you, who can be your guru
