Old Mar 19, 2012 | 10:07 PM
Mrmiata's Avatar
Mrmiata
Default Re: Catch can with a catchy appearance
Originally Posted by turbomar
Here's my own interpretation of a catch can. Is is designed with the 4cyl. tuner car in mind, so, I added a 3rd port to allow venting of both valve covers. The can has a level indicator so you know when it is time to service it.
You can get it here: SILVER TURBO OIL CATCH ALUMINUM CAN TANK RESERVOIR JDM 750ML UNIVERSAL RACING | eBay
Couple questions on this..
Your added port.. is that tubing running back to the throttle body port?
When you added your port.. I'm guessing you would have noticed any baffeling in it?
Did you pull the original ports (looks like they are removable)..dip tube to direct through baffeling?
And last but not least.. couldn't you add a "y" type adapter and use the original ports only?
