Old Mar 21, 2012 | 04:45 PM
turbomar's Avatar
turbomar
Default Re: Out of Storage and back on the road...
Originally Posted by stevedask
I consider this car as a limited production model that will become a classic, that's why I think many want to keep it away from the salt as much as possible. Although I agree with the winter we had this year you could have driven it and not seen too much salt at least in my area it only snowed a few days.
PS - Took out the XF last weekend, only problem I had was the brakes seem softer than when I put it in storage & the BAS EPS light cam on a couple times. I'm hoping storing it didn't gum up the brake fluid or cause some seals inthe system to fail... Anyone have a similar issue when they took theirs out of storage?
Hi Steve
Did you have the battery disconnected? If so, the ESP needs to calibrate on start up by doing a full range steering(left and right) turn and then the light will go out
