Old Mar 21, 2012 | 11:31 PM
  #77 (permalink)
GraphiteGhost
Default Re: HOW TO replace headlight bulb. Pictured step by step instructions
Originally Posted by XFireCrazy
Just replaced all 4 of my lights with H7's. Took about an hour or so to mess around with stuff and figure out what I was doing, but now that I have done it once it is really only a 5 minute job per bulb. Except passenger side high beam with the radiator overflow bottle in the way. I removed that so I could get to it.
When I went to drive the car I realized that the low beams were both pointing almost straight down and not projecting out on the road. I could not see anything. lol I just went out and adjusted them a little bit since they sit very loosely in the hole. I am surprised those clips are not tighter in order to hold the bulbs in place better. Anyone else notice this looseness? Maybe the previous owner bent mine a bit??
Thanks for the pics and discussion on this. I was terrified to tackle this at first with everyone posting their issues and complaints. I guess I am lucky that I have little nimble fingers.
The bulbs are keyed a certain way. One set is tab up, the other set is tab down. You have to be sure they are seated correctly or the bulbs will not aim correctly. And that clip has to be seated correctly as well. Good luck!
