Old Mar 23, 2012 | 08:58 PM
Mrmiata's Avatar
Mrmiata
Default Re: 2004 Crossfire Parasitic drain
Originally Posted by Missfire
Yes I have already searched for an answer on here and just with Google. The only answer I am getting through these methods is a temporary or band-aid solution, which is to disconnect the fuses. Now that I have those fuses that I have found to be the problem already disconnected, I obviously cannot use the features that the fuses were controlling. So my question is again if the fuses are the problem is it just a matter of replacing the fuses or is it something else like wiring, corrosion or something else that someone on here has experienced or knows about. Thanks for the response there onehundred80 but to answer with Use Search means you have little experience to provide an answer which negates a forum experience. Any other possible solutions from someone with experience and perhaps, a Crossfire would be very much appreciated
OUCH.. 180 he don't have a missfire.. he just hit you on all 6 cylinders!
You need a kinder approach when responding.. Here's a sample..
see.. aesthetically pleasing and makes your point..
