Old Mar 31, 2012 | 01:31 PM
JHM2K's Avatar
JHM2K
Default Re: Okay you fine forum peoples, time to vote
Originally Posted by Airscape
Any particular reason your not going with the 32 drilled rotors? I figured the whole setup would be a straight swap.
The Zimmermann rotors are drilled in the exact pattern as the OEM. With the OEM rotors, the rears are blanks and I'm a **** about matching F/R. OEM is certainly cheaper
