Old Apr 1, 2012 | 06:26 AM
TerryR's Avatar
TerryR
Default Re: Help with top issues please
Originally Posted by D. Lee Hendershot
I'm having troubles also. When the temperature is around 80 degrees, I have problems. If the top is up..the "red led" on the consol flashes, and top will not move. Same thing happens if the top is stored in the trunk. The other day the deck lid opened,but top would not move and the lid would not close. After several hours, parked in my garage, the lid then closed when I activated the switch.
Then I tried to reopen the top. The deck lid opened and the top raised straight up and then quit moving. A day later, the hydraulic pressure dropped off and the deck lid came in contact with the canvas top. I manually raised the lid and the top droped into the trunk. I released the lid and it droped down to the body. I did have to apply hand pressure to get it to latch. The trunk would not open after that. I took the car to my local Chrysler dealer because I have the extended warranty. They tell me there was no error codes so they raised the top by activating the switch on the consol. Now the temperatures are in the 50's and they can not get the top to malfunction. Hopefully there is someone out there that has an answer to my problem Flustrated in ST. Clairsville, OH
I could only put this down to a faulty Microswitch working intermittently. I would buy another, as they are only cheap on E-Bay, I always have a new spare available. I am told, there is also a Microswitch associated with the windscreen lock handle, whether this may be faulty and only working intermittently????
