Old Apr 1, 2012 | 03:47 PM
D. Lee Hendershot's Avatar
D. Lee Hendershot
Default Re: Help with top issues please
Originally Posted by TerryR
I could only put this down to a faulty Microswitch working intermittently. I would buy another, as they are only cheap on E-Bay, I always have a new spare available. I am told, there is also a Microswitch associated with the windscreen lock handle, whether this may be faulty and only working intermittently????
TerryR...Thanks so much for taking the time to respond to my problem. I have couple question...hope you can answer.
As an elecrtician for 40 yrs. the microswitches i am most familar with are mechanical devices and normally are not temperature sensitive. Could the devices (microswitches) used in the Crossfire Roaster top be solid state devices that may be temperature sensitive. Do you know if they are "OR" or "NOR" switches?
I know ther is a sensor or switch in the trunk that is activated when the devider(cardboard panel) in raised to allow the top to safetly be stored in the trunk.
Where is the windscreen lock handle? Is this the handle you turn to unlach the top to put it down?
Are there switches in the windshild framework? What about the deck lid?
