Old Apr 2, 2012 | 08:28 PM
D. Lee Hendershot's Avatar
D. Lee Hendershot
Default Re: Help with top issues please
OK Mark thanks for the info and let me go over my scenario again if you can help.
1. When the latch is released and top pushed up, the windows go down automatically. Do you agree the microswitch in the w/s frame is functioning correctly? I do.
2. The microswitch on the partition panel is correctly adjusted and seems to be working properly. Also I disconnected the switch at the connector, jumped the plug over at the wire harness end with a paperclip to bypass the switch. Also I left it 'open' and tried it. No dice either way. So far I don't expect this to be the problem but a new switch has been ordered.
3. I need some advice/information on the trunk lock sensor you speak of. How can I test it, bypass it temporarily, etc....
Any additional information would be greatly appreciated.
James
Thanks again gentlemen
