Old Apr 12, 2012 | 03:21 PM
pizzaguy
Default Re: Who wanted temp sensor probe?
Is the sensor probe mounting bracket a removable part? Dealer says there's no listing. My sensor keeps slipping out from the mount. Squirrel Crusher
If this is still a problem, I can tell you what I did. I drilled out the hole, filed down the back of the bracket, and pushed the probe in from the front - and then connected the connector from behind.
I don't fear water getting into the connector for three reasons:
1) I added a little silicone sealant to the "fins" of the connector.
2) I think the front cover will keep most wind and water from getting in.
3) It is not a critical function anyway - but I sure do use the temp indicator a lot!
