Old Apr 21, 2012 | 09:05 PM
32krazy!'s Avatar
32krazy!
Default Re: Need new brake pads... Help!
Two sources found ( Are ceramic brake pads better than semi-metallic brake pads? - Yahoo! Answers ) and ( Brake Tech - Why Ceramic Brake Pads? ) say ceramic pads actually extend life of all the components (pads and rotors). I cannot see how a formulation of ceramic and copper can wear down a steel rotor more than a composit semi-metalic pad. In fact the tirerack article third paragraph says just that, the semi-metalic pads increase rotors wear more. Just saying!
while you are correct the semi pads grip much harder when heated up and matched with the proper rotors. the ceramics are a softer compound and tend to fade from repeated hard use.
in short they both have their uses but it depends on the driving style.
my rotors have a brinell hardness of 277 and would destroy a set of ceramics as well as ruin the rotors due to the pad sticking to the rotor.
