02TBSteve
Smokin' Red, Thx for the valuable and obviously inexpensive fix to the height adjustment situation. Did you have to use longer bolts to compensate for the wood thickness? Do the bolts unscrew from the underside of the car or inside?
Yes you have to use longer bolts to compensate for the 2x4. The bolts come out from on top of the seat tracks, They bolt into the floor, the nuts are welded in the floor, the bolts are, i think are 10mm allen head bolts. Good Luck
