Passenger Seat Height Adjustment?
Old Apr 22, 2012 | 08:38 PM
02TBSteve's Avatar
Default Passenger Seat Height Adjustment?
Has anyone tried to modify the passenger side seat so that it sits higher? My wife finds it virtually impossible to get out of the Crossfire without a "boost" from me. What about installing the power seat adjustment/mechanicism from the driver-side to the passenger side? Is this part available?
Old Apr 22, 2012 | 11:35 PM
Thirteendog's Avatar
Default Re: Passenger Seat Height Adjustment??
I don't know about the SLK320s but the SLK32 has up and down adjustments for the passenger side. They're passenger seats has all of the movents as the driver seat.
Old Apr 23, 2012 | 09:13 AM
02TBSteve's Avatar
OK....that's a start. What is the difference between an SLK 320 and an SLK 32? Would anyone know if the seat mechanisms/attachment holes are the same on the Crossfires?
Old Apr 23, 2012 | 10:56 AM
Kodebuster's Avatar
My lady has the same compliant, the seat is way to low for her comfort level.
I keep a throw pillow in the trunk, which she'll sit on, so her eyes can clear the dash (she's small but carries a big punch)...lol...
I'm wondering if you just replaced the passenger seat, with a Driver seat, would that just work (plug and play)...???
Also wondering if the existing rails can be jury rigged and maybe raised (although this would be a permanent fix, but reversable)...
Old Apr 23, 2012 | 11:38 AM
Mr Kilmouski's Avatar
The seats in a SLK320 are the same type as in a Limited. Both electric. Unfortunately drivers and passengers are not interchangeable, The controls would be on the inboard side and and the inboard side is fabric not leather.
Old Apr 23, 2012 | 11:49 AM
lildaddym's Avatar
Wonder what a seat costs, and if you can get the same color combinations...
Old Apr 23, 2012 | 11:53 AM
Smokin Red '06's Avatar
I cut two 2x4's the same length as the seat tracks and painted them black, drilled holes up through the 2x4's to accept the seat tracks, then bolted the 2x4's to the floor using the orig. holes in the floor.Work's fine, just the right height.
Old Apr 23, 2012 | 11:55 AM
lildaddym's Avatar
Interesting solution...not much adjustability, nor is it easy...but a solution!
Old Apr 23, 2012 | 04:42 PM
02TBSteve's Avatar
Smokin' Red, Thx for the valuable and obviously inexpensive fix to the height adjustment situation. Did you have to use longer bolts to compensate for the wood thickness? Do the bolts unscrew from the underside of the car or inside?
Old Apr 23, 2012 | 04:59 PM
Yes you have to use longer bolts to compensate for the 2x4. The bolts come out from on top of the seat tracks, They bolt into the floor, the nuts are welded in the floor, the bolts are, i think are 10mm allen head bolts. Good Luck
Old Sep 5, 2013 | 09:07 AM
jimmirehman's Avatar
Any reason why the 2x4 method would mess up airbag sensors or anything? I don't want to put my passenger in harms way.
Old Sep 5, 2013 | 09:32 PM
srbaker's Avatar
Same problem, find passenger seat too low. Are the leather colors the same in the UK? Could a drivers seat from a right hand drive, if it exists, be ordered and installed over here? Then the controls would be on the RH side of the seat.
Old Sep 5, 2013 | 11:16 PM
No problem with airbag sensors that I can see.
And I would think a European driver's seat would be just the ticket - but talk about a hard item to find!
And E X P E N S I V E !
Old Sep 6, 2013 | 08:44 AM
has anyone else done the 2x4 mod?
Old Feb 23, 2014 | 12:23 AM
cobraken's Avatar
Looking for a solution that allows adjustability. Could the lift from the driver's side be adapted to the passenger seat? The switches seem to be the same for both seats
Old Jul 25, 2015 | 12:58 PM
blhoov11's Avatar
I have the same issue with my 05 roadster. Does the SLK roadster have a passenger power seat? If so, will the lower seat frame track assembly bolt up to the Crossfire seat? The switches are on the side of the seat base with all the wiring from the factory and appears that this was an option in 05. Is there anything available from MB or Mopar?? blhoov11@verizon.net 05 roadster
Old Jul 26, 2015 | 01:24 AM
Red Runner's Avatar
I have an 02 MERCEDES SLK320 SLK230 BOTTOM SEAT RIGHT PASSENGER SIDE OEM assembly that I purchased off of ebay for $139. Red Dog gave me the heads up on this part. It is too hot here to get this installed at this time. Once it is installed I will provide an update.
UPDATE: https://www.crossfireforum.org/forum...nger-seat.html
Old Jul 26, 2015 | 07:56 AM
If your passenger is too short to see out of the window while using the seat belts, you can always make this cheap solution for less than $5.
It is portable as well.
Old Jul 26, 2015 | 08:10 AM
Bill F's Avatar
My wife sits on a cushion.
Valk
Jul 12, 2021 09:49 PM
steps
Apr 26, 2016 06:21 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Billy22Bob
Oct 1, 2015 05:34 AM
Charlesl
Sep 30, 2015 10:46 PM
