Old Apr 25, 2012 | 10:14 PM
James1549
Default Re: Crossfire turns over but wont start
Why would you consider the ignition coils? The crankshaft position sensor controls when the coils fire so I would go with a new sensor first. Your first code deals with O2 sensors and MAF sensor. You may need to go there if the CPS doesn't fix your trouble. Your second code concerns the trans. Get the engine running properly first.
<< but it wont even crank after a full day of not touching it.>>
Not sure what you mean here. Please explain. Does your battery test good?
James
