Crossfire turns over but wont start
Old Oct 11, 2022 | 11:02 PM
GraemeQ's Avatar
Default Re: Crossfire turns over but wont start
hi mate where is the fuel filter located on the cross fires?
Is it under the engine cover accessible or under the car some where?
Old Oct 12, 2022 | 09:25 AM
Index of Crossfire problems and repairs - CrossfireForum - The Chrysler Crossfire and SRT6 Resource
Old Oct 12, 2022 | 09:57 AM
The fuel filter is also the pressure regulator and is mounted next to the fuel pump, under the car just ahead of the differential on the passenger side.
As you might have read here before, make damn sure you buy the OEM part, I got mine from Rob at Needswings for $44.
If you suspect fuel pressure issues, it is wise to buy a cheap ($35-50) kit to measure pressure at the fuel rail. It must be 58-62psi anytime the key is on.
Just "Looking at" the fuel filter/regulator is a waste of time.
Old Oct 12, 2022 | 10:11 AM
bluecoupe's Avatar
Pizza he's a Kiwi so I expect it will be on his driver's side.
Old Oct 12, 2022 | 02:46 PM
If he interacts with AMericans a lot, I'll bet he's way ahead of you OR me.
Old Oct 12, 2022 | 10:32 PM
Jack G's Avatar
I am completely unfamiliar with our MB electron ignition system but I have had some experience with antique vehicle electronic ignition conversions. A Petronix ignition system which uses a hall effect module requires an input voltage of >4.3 volts to function. If our MB ignition system functions in a similar manor your battery output might be below the required potential needed for ignition to occur.
I would replace the battery, thoroughly clean the cable connections, and change both the cam and crank sensors with Bosch replacements.
Old Oct 13, 2022 | 01:26 AM
GraemeQ's Avatar
hi
bought a diagnostic reader and plug it in. It found my car but it said no faults found? Got the the solder joints redone and new CPS. After that inial start of about 2 seconds it just turns over with no attempt to start Grrrrr
Old Oct 13, 2022 | 10:05 AM
With the RCM, many times it is bad relays. Not just bad solder joints. RCM stands for relay control module.
Old Oct 13, 2022 | 04:46 PM
GraemeQ's Avatar
cheers mate
Do you know if I can buy replacement relays separately?
A new RCM is $800 NZ
Many thanks
Old Oct 13, 2022 | 05:53 PM
Jack G's Avatar
Dear GraemeQ
A new RCM is available via FCPeuro.com here in US for $164. usd. Check their site https://www.fcpeuro.com/products/mer...lay-1705450305.
You can cross reference MB SLK320 parts for xfire use. Maybe you can locate the same SLK320 part for less at a local MB supplier in NZ or have someone in the forum ship one to you unless your customs will open the package.
Just a thought.
Cheers
Old Oct 13, 2022 | 05:55 PM
You can also contact tighed1@hotmail.com. He rebuilds them and maybe he could help.
Old Oct 13, 2022 | 06:34 PM
cheers mate
Many thanks
For a lot less than that, you could send it to DJ and let him refurbish it. HOPEFULLY, it won't sit at customs too long.
Old Oct 13, 2022 | 08:05 PM
GraemeQ's Avatar
many thanks for everyone's assistance
Bookio
Jul 16, 2021 11:03 AM
gregcormier
Jun 28, 2013 12:09 AM
steevyn
Nov 11, 2012 11:30 AM
mickland
May 20, 2012 07:17 PM
Bob_Ham
May 19, 2010 12:11 AM
