Old Oct 12, 2022 | 09:57 AM
pizzaguy
Default Re: Crossfire turns over but wont start
Originally Posted by GraemeQ
hi mate where is the fuel filter located on the cross fires?
Is it under the engine cover accessible or under the car some where?
The fuel filter is also the pressure regulator and is mounted next to the fuel pump, under the car just ahead of the differential on the passenger side.
As you might have read here before, make damn sure you buy the OEM part, I got mine from Rob at Needswings for $44.
If you suspect fuel pressure issues, it is wise to buy a cheap ($35-50) kit to measure pressure at the fuel rail. It must be 58-62psi anytime the key is on.
Just "Looking at" the fuel filter/regulator is a waste of time.
