Old Apr 27, 2012 | 10:15 AM
  #38 (permalink)
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: Wrapping my headliner in carbon fiber next week
I pulled it out and then back in through the passenger door. I tilted the seat forward and dropped the front down as low as it would go, leaving the back as high as it would go. I had to slightly flex the rear mounting tab (it gets covered by the rear plastic panel) to push it in the door opening towards the very end.
Once I got it in I aligned the rear mounted tabs and holes, then screwed the sun visors in a little to hold it in place while making sure the side and rear edges align and press into the slots in the rubber gaskets.
After it was aligned and pressed into place I put the plastic retainers into the rear mounting tabs and finished tightening the visors.
Hope this helps?
