Old Apr 28, 2012 | 01:34 PM
onehundred80
Default Re: What is intermittent "beep"?
Originally Posted by crrroger
Occasionally I hear a "beep" which seems to come from the far left side of the instrument cluster. It occurs so rarely that I can't define a pattern or see if there is a warning light that accompanies the "beep". I can best describe it as similar to a radar detector warning beep but it only occurs once and then is silent....for a while.
Other than this minor irritant, my "new" Xfire is perfect in every way.
Any one have any ideas about the "beep"?
Thanks,
Roger
The chime comes on when it is initially sensed that there is low level of WW fluid and fuel. The warning lights come on at the same time, I have had this happen.
On checking the Repair manual there is mention of Rad fluid level, drivers door ajar, I may have had that as well, seat belt switch, high beam lamp and illumination control module fused ignition switch output(?).
It may come on when the FSS display changes, I have never seen this. There are probably other causes as well, my 300 beeps for all sorts of reasons.
