onehundred80
Depressing the clutch operates a switch that switches off the cruise control momentarily, I wonder if this has anything to do with the problem, even if the cruise is not on.
180, this is a very interesting post, and good to know.
I rarely ever use Crusie, I just don't trust that set-up in any car.
Although I would have thought that depressing the Clutch would just shut it off, rather than a momentary action.
If I designed it, the brake, gas pedal, or clutch, would cause the CC to deactivate.
Any ideas on the reasoning behind this.
It's a strange bird that depresses the clutch, not change gears, without playing with the gas pedal a little. Unless maybe your going to neutral with a brake to slow or stop coming to mind...
