velociabstract
The stock SRT-6 front rotors are 330mm and I have a set. I assume they wont work but maybe I should do a trial fit. Hummm. I don't know about those sleeves/spacers 32. Do you think they'd stand up to Puerto Rican braking?
Les
front rotors wont work on the back les. ebrake remember? the sleeves will stand up to whatever you toss at them. their only purpose is to allow you to run the 10mm oem mount bolts . they fill the tiny gap because the cl55 use a 12mm bolt.
