SparkieSRT6
Mine is an OEM dipstick for the 722.6 transmission.
The first mark for the low range @ 25 deg C is 5/16" from the tip then the high range mark @ 25 deg C is 3/4" from the tip. Then the next markings are for the low range of 80 deg C which is 2" from the tip to the high range of 80 deg C which is 2-1/2" from the tip.
Here are some pics to show what I mean :
http://i41.tinypic.com/v7uq8k.jpg
http://i43.tinypic.com/2u8fgr5.jpg
QUOTE!
GraphiteGhost
Re: Another trans dip stick
Would it be a good level if it was between 1 and 2 inches on the zip-tie home-made dipstick? I know it must bottom out in the pan (carefully) when you take the reading.
amx1397
look at the links above and look at the picture and you will see that 1 inch from the bottom is ok but on the lower side of low/ if it were me I would be right in the middle when the two notches, be careful it builds up very quickly, looks like to me you need to add,like one fourth of a quarter .. maybe less. jim
