onehundred80
The engine must be running and had the gear shift cycled a few times and the temperature considered. What is the temp. of the oil you are measuring?
as long as you warm up the car so that the transmission is it least warm. The level Between 1 and 2 inches from the bottom closer to the two inch mark,your good. the temperature Is no longer a factor when measuring it this way,, jim
P S this is what a Mercedes mechanic told me, then I verified it with two more Mercedes mechanics at two different dealers
