So it sounds like you are looking to lower with new springs and shocks right? There are some great write ups here that are spot on
How to remove front springs to DIY lower;
https://www.crossfireforum.org/forum...5-srt-6-a.html
How to remove rear springs to lower;
https://www.crossfireforum.org/forum...-pictures.html
keep the comfort with adjustable sway bar links;
https://www.crossfireforum.org/forum...your-ride.html
https://www.crossfireforum.org/forum...djustable.html
with a set of these to correct rear camber;
https://www.crossfireforum.org/forum...-hardware.html
and how to install;
https://www.crossfireforum.org/forum...mber-arms.html
The front shacks are straight forward, the rears need the two fabric covered panels inside the back hatch area removed to remove the 17mm shock nut. Some members have made an access door/window for the adjustable Koni's
Hope this helps if not the search feature top right is REALLY easy.
