Old May 14, 2012 | 11:41 PM
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: Help with IC pump
glad to hear your up and running again.
Correction to what I said earlier, the johnson is smaller than the oem, not bigger. Also the smaller pump right under the headlight assembly that I was talking about is above the IC pump.
Originally Posted by JesseJamessrt6
I had my lower fender well skirt off and it looked like it would come out without too much grief. Sounds like I am wrong and I am tagging along here as my replacement pump shows up in about 5 days.
When I had the headlight housings out to install my HID's I saw where the pump bracket would be impossible to get out without removing the headlight assembly but thought the IC pump didn't need that removed.....
I ordered a johnson and everyone on MB world said it is slightly larger in diameter, should be interesting once I get into it by the sounds of it.
Good luck and keep us posted, thanks!
