Mrmiata
Xentec 6000k.. blue'r than anticipated..yep.. but have gotten used to and like. Plug and play easy with no issues. Only one slight concern.. one bulb seems to "flair" when first turned on.. will see what happens long term I guess.
FYI - my "slim ballast" Xentec kit experienced the same problem. I think its because, for whatever reason, that kit needs a relay. The flaring (it was in the passenger side bulb), continued - and after a while if you looked closely, that bulb was always constantly flickering slightly. That bulb or ballast ultimate kicked the can (I didn't check which one). And I replaced the Xentecs with the original China regular ballasts. No flaring even since.
