Old May 17, 2012 | 11:10 AM
JHM2K's Avatar
JHM2K
Default Re: Would you call THAT a race???
Originally Posted by sk8erjosh09
Really???
I havent read much about them but given the price tag I always figured they were mid-high 11 ET cars..... but then again I do not make the dough required to investigate those things thoroughly...lol
Hahahaha no a 370Z is good for high 12's if you install a very good driver. Seeing as most drivers aren't, majority of the 370's run low 13's. In the corners, it gets more interesting as the suspension geometry of the Z34 is quite brilliant. The only real achilles heel of the Z34 is brakes... even with the upgraded Brembo package, they're prone to overheat. We have a significant torque advantage and a 300# weight advantage. Providing you get a good hook, the Z34 is your oyster. Don't attempt to race them in a Limited, though... you'll have a bad time.
Originally Posted by The Beep
JHM2K is modded up pretty good. I'ld imagine there's little he can't do as long as the tires stick.
x2 on that last statement, hahaha. My 12.3 was run on streets with a 1.8 60' time... but that was a prepped race track and I had scrubbed the tires with a warmup spin. My car is strong but certainly not invincible. That being said, I haven't lost a challenge yet on the Mexican highway system.
