Old May 21, 2012 | 10:51 AM
  #107 (permalink)
Kola52's Avatar
Kola52
Default Re: Trunk Lid Jammed
Look by your license plate and see the lights, remove the light on the right side take a flash light and look in the hole, you'll see this white accoridan looking thing, take a screw driver and either push or pull it ( I don't remember if it goes the left or the right) and it will pop the trunk open. You can then manually put your top down. My husband had to disconnect the motor to the top for a few minutes to get it to reset to factory default.
good luck with it!!
