Trunk Lid Jammed
Old Sep 24, 2024 | 01:30 PM
  #201 (permalink)
wayne keast's Avatar
Default Re: Trunklid Jammed
These work well.
trunk won’t open in my Chrysler Crossfire
Old Sep 26, 2024 | 11:02 AM
  #202 (permalink)
Default Re: Trunk Lid Jammed
Not enough information,, limited ,,roadster or coupe ? key fob does not open trunk or does it
(The fob) unlock it then it will not open. jim
Old Sep 26, 2024 | 05:33 PM
  #203 (permalink)
Jim is right, that is not enough to tell us what is going on with the car. If it's the Roadster electric lock, you can follow the procedure to force it to unlock, which often works, but then you MUST determine why it did this or it will just do it again.
If the latch button MOVES but the trunk won't open, it's the pneumatic lock.
If the latch button is "stiff" and won't move, then it's the electric lock.
To force the electric lock to unlock, DO EXACTLY THIS:
With the ignition “On” press the “Top Down “ button.
While holding the button turn off ignition and hold button 10 seconds.
Trunk should unlock.
Old Sep 27, 2024 | 10:59 AM
  #204 (permalink)
AnnaBananna's Avatar
​I JUST had this issue Monday, someone answered my post and gave me the info below...it MIGHT not solve your issue, but it's absolutely worth trying! (can you tell me how I start a new post?) I so hope this works for you.
You
Fri 9/27/2024 9:17 AM
Default Re: Convertible Top HELPPressure release procedure
1) turn car on
2) Press the down button, keep holding the button
3) turn the car off
4) Release the button after 10 seconds or the light goes out on the switch
Osusannah
Feb 12, 2024 01:49 PM
RamblinShamblin
Aug 12, 2017 10:55 PM
Reliableron
Oct 17, 2015 10:19 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
xjken
Sep 13, 2015 10:18 PM
