Old May 24, 2012 | 02:58 PM
onehundred80
Default Re: Spoiler motor...
Originally Posted by JHM2K
Unless you guys fancy paying $784.80 from oediscountparts, I'd stick to a used one.
Here is a link, with part number:
DRIVE. Spoiler. for 2008 CHRYSLER CROSSFIRE 3.2L V6 SOHC 18 Valve, 6-Speed Manual Limited Roadster (05096800AC)
I looked it up manually on www.oediscountparts.com and found they offered a 25% discount (search under BODY HARDWARE-->LIFT GATE-->SPOILER-->spoiler)
Here's the rub: the motor itself is not separately serviced. I've contacted Webasto (the manufacturer of the spoiler) directly, since they're a vendor for Nissan as well. I had them run the Chrysler part number (05096800AA (which supersedes to an 05096800AC)) and they confirmed it is only available as a complete assembled unit.
Now, an option may be to find any stamping numbers on the motor and try to contact the direct manufacturer of the motor, as that is likely provided by a Tier-2 supplier to Webasto. One of the numbers on the spoiler assembly, A193 75 00 060, does not exist in any record.
But, as far as a Chrysler replacement part, it's the whole assembly only. Sadly there is no R170 part that can be had for cheaper, because this is specific to the Daimler R193/ZH chassis (aka the Crossfire)
See attached photo
Being on the cheap side by nature when I can avoid grossly inflated prices for simple and often repairable items, why not see if the motor is repairable? Too often we are suckered into the disposable ideology prevalent these days. After all how hard can it be to repair?
