Re: A/C blows hot and cold at the same time
Or if both controlers or set to cold then the heater control valve is not closing on one side.. Check heater hose it will be hot if engin has heated up. The one hose runs into two valves. Check to see if one of the two hose leave the valves hot. if so the that valve is open. Bad valve or control module.
