Old May 31, 2012 | 05:04 PM
onehundred80
Default Re: spraying oil out of the Dipstick tube
I know when I did my first oil change with Steve we replaced the O ring with a slightly bigger one. Went from sliding in and out with no friction to having to pull it out (not yank).
A bigger one works perfectly as long as it bigger in the correct manner.
The standard O-ring size is a Parker size #2-014 which is nominally sized 1/16" x 1/2" ID x 5/8"OD.
Stretching a Parker size #2-110 with the nominal sizes of 3/32" x 3/8"ID x 9/16"OD works perfectly. The stretching reduces the cross section and increases the ID and OD's. The OD when installed is about .660"
You cannot use a bigger 1/16" section O-ring, and a bigger 3/32" section O-ring #2-112) with a 1/2"ID would have a 11/16"OD (.687") which is too much.
The correct size O-ring comes with the oil filter, I'm not sure if it's one of those used but you could always use the old one anyway.
Last edited by onehundred80; May 31, 2012 at 08:39 PM. Reason: Oil filter note added
