Old Jun 11, 2012 | 12:10 PM
GraphiteGhost
Default Re: Battery Loss of Charge
Originally Posted by skarlet
My wife's 05 Crossfire rear window had fallen out and rain got into the trunk, like an inch. The fog lights parking lights all stay on. I pulled fuses to turn these off. The convertible does not work. The lock/unlock does not electronically work. The battery would not take a charge 24 hrs and barely turned the engine over. Would this security module cause this. Does anyone have any good suggestions. We have removed most of the water and are currently trying to dry it out the rest of the way. I replaced the battery, when I connected the terminals it gave indication of a load i.e. sparks so we are leaving it disconnected except when we need it. All this because Chrysler's crappy rear window falls out and Chrysler will not fix it. Any thoughts would be welcome.
Sorry your having this problem. I suggest you get under the rear of the car and remove the right side rubber plug where the lower bin is (left side is the tire repair kit, right side is where the central locking pump is located). When you remove that rubber plug, if water pours out, then you found your problem. The central locking module is all wet. Fixing this could be expensive. You have to dry all this stuff out and that involves removing all the trim panels and getting into those bins to get that module out. The coupe involves removing the trim from the upper sides, the sides, the lower rear (to allow access to the foam inserts in the bottom of the trunk where the flat repair kit is) and then removing the central locking module in the right side bin. I don't know how the roadster comes apart, maybe someone with experience in this model can chime in to help you. Again, first take out the rubber plug under the rear right side bin of the car. Good luck in fixing this!
