blackpepper
Is it normal for the outside airtemp sensor to be 10 degrees off.I found some type of sensor above my drivers side foglamp just hanging any idea what sensor this is and where it goes.
It Is probably your ambient air temp sensor. Same thing happened to mine shortly after I bought the car. There is a small hole in the lower grill section on the drivers side that the sensor snap-fits in. The little catch on the sensor may not have enough tension to hold it in the opening. Recommend putting a bead of silicone adhesive round the base of the sensor and just plug it back in the grill. It will work fine. You'll have to remove the under-engine skirt to get at it, though, if you haven't already...
