Old Jun 23, 2012 | 06:38 PM
Mrmiata's Avatar
Mrmiata
Default Re: High Power ERROR FREE Projector Style Back Up Lights
I like the description in the body...
Features:
  • 6000K Xenon White
  • Size: 0.78" in diameter, and 2.00" long
  • Equips with high power FLUX LED emitter plus 3x optical projector to maximize the lighting output
  • Lighting output: approx 900 lum
  • Voltage: 12V
  • Lifespan: 20000 working hours
  • This LED bulb is polar sensitive, so in case the bulb won't light up, please flip it 180 degrees
Note: Since the LED bulbs have lower wattage, therefore when installing on some newer European cars, you need to tap on load resistors to get rid of the error code on dashboard or flickering issue.
