RED DOG
No in line resistor is needed with an ERROR FREE bulb. When you posted the specs I wish you had not put in the part about "resistor may be needed". You've only confused the intent of this post. Maybe you can edit your post? THANKS
The seller is contradicting their self. You can't advertise the bulbs as Canbus Error Free and then add the note about needing resistors in the same ad. Makes no sense dude. Mrmiata is simply trying to explain this to you.
I have purchased LED's from iJDMToy and had zero issues with the bulbs. But they need to fix this ad.
