Old Jun 30, 2012 | 08:13 PM
  #428 (permalink)
rekcah's Avatar
rekcah
Default re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Sticky Ignition Fix Revision #3 pdf is attached with picture.
Change Log
Added symptoms (Thanks onehundred80 for suggesting this)
Added telescoping steering wheel
Added very important first step
FYI - Removing the tumbler allows you to just press the pin in on the outside of the assembly to remove it. And to remove the tumbler you need the key to turn to position 1. Drilling the pin bypasses the need to remove the tumbler. Hope this helps everyone.
**12/28/13 Changes to v4 - onehundred80 pointed out that in step 6 removing screws #1 & 3 are optional.
File Type: pdf
File Type: pdf
