Old Jul 4, 2012 | 01:14 PM
Mrmiata's Avatar
Mrmiata
Default Re: Loss of all Power
Originally Posted by Catherine
Thanks all! I've removed and cleaned both battery cables. (The negative was slightly corroded and not as tight as it could have been - not loose, couldn't rotate it by hand - but not tight.) Hopefully this does the trick. After reading some posts I originally thought it was the CPS or RCM. However, the posts didn't seem to match the complete loss of power - no power to any electronics either.
"This post is in response to the MANY occurrences of the "Mystery No Start" issue. Symptoms being car will die and/or will not restart but may restart after waiting for a while. Also, when attempting to start the engine all electronics work but the engine will not crank"
Also, I find it strange that popping the hood was enough to shake some life into the car. Seems more likely a bad connection issue then a sensor issue, but still strange none the less. You'd think hitting one of these Michigan potholes would cause the same affect. If it occurs again, CPS/RCM is next.
I'd make the RCM next.. cps everything works but the motor firing.. "Been there" ..
