aquarilized
hey guys, i was wondering about the a/c in the crossfire. in my car the a/c seems to blow slow even when i have the settings at max. is this normal or is it mine only? any help would be appreciated. thanks.
My fan blows a lot of air out on the high setting. Is your AC still cold? If not, it could be an AC issue. If its still cold and the fan speed doesn't respond to higher setting, then it may be the fan or the fan switch. Check the switch first. It could be it's not changing speed because its worn out or not connecting from setting to setting.
