Air conditioning blows slow
Old Jul 16, 2012 | 05:37 PM
aquarilized's Avatar
Default Air conditioning blows slow
hey guys, i was wondering about the a/c in the crossfire. in my car the a/c seems to blow slow even when i have the settings at max. is this normal or is it mine only? any help would be appreciated. thanks.
Old Jul 16, 2012 | 06:12 PM
PNA's Avatar
PNA
Default Re: Air conditioning blows slow
My fan blows a lot of air out on the high setting. Is your AC still cold? If not, it could be an AC issue. If its still cold and the fan speed doesn't respond to higher setting, then it may be the fan or the fan switch. Check the switch first. It could be it's not changing speed because its worn out or not connecting from setting to setting.
Old Jul 16, 2012 | 06:17 PM
Not normal.
Blower motor - 05098030AA ( or leaves clogging it up )
or most likely the blower control module - 05096900AA.
( outside chance it could be the switch, but not likely )
best price is MB price for the control/resister module - try :
http://www.carpartswholesale.com/v5/...versal:0)&sv=0
for the blower motor :
or you could get a used blower / module from car-part.com - many available
Old Jul 16, 2012 | 06:24 PM
The AC is cold but is very low when at max setting. it is not much difference from low to high setting. thanks I will look into switch. Thank You very much, i appreciate your help.
Old Jul 16, 2012 | 06:26 PM
Originally Posted by alaxfire
Not normal.
Car Part Wholesale - Auto Parts and Accessories Catalog - Blower Motor Resistor For 2003 Mercedes Benz SLK320 Base 6 Cyl 3.2L
Car Part Wholesale - Auto Parts and Accessories Catalog - Blower Motor For 2003 Mercedes Benz SLK320 Base 6 Cyl 3.2L
ok cool, thanks for your help. i will look into these as well. very much appreciated.
xfireohio
Jul 20, 2020 12:03 AM
waldig
Sep 2, 2015 11:02 AM
glover
Aug 23, 2015 05:07 PM
Pacemaker
28
Aug 16, 2015 07:33 PM
waldig
Aug 14, 2015 01:02 PM
